B&W DM3000 issues - advice needed
gajraaj
Hey guys and gals..
Picked up my first set of vintage speakers today. B&W DM3000.
Seems to be in fairly good conditions. Still need to clean and listen a bit more.
First issue : I hear a lot more sound coming trough the top tweeter ( even if I turn the treble down to zero). This is making the sound a bit high pitched and even a bit shrill. Though all drivers are working fine.
Second issue : the Kevlar drivers on one of the speakers have the center portion a bit “dimpled”. Does this effect
Any thoughts?
Thanks in advance.
View media item 21732
View media item 21731
View media item 21730
Nice looking speakers, should sound good, well worth restoring. What are you driving them with?
I would start by listening closely to each individual driver at low volume to make sure everyone is working.
If you go here http://bwgroupsupport.com/ and select service manuals, go to B&W service manuals, then go to DM Series then DM3000 you can get the service manual for these speakers.
At present I am driving them with a NAD 326 Beee .maybe that’s part of the problem.
Waiting for my Sansui BA-F1 to arrive sometime in next two weeks.
thanks.
Did you recap them at some point in time?
I never did because everything worked on mine. I had no driver or crossover issues. The only problem I had is the top plastic peice was warping and the fabric on the metal grill was starting to snag.
There is an audio mod under B&W dm12 to disengage the APOC (auto protection overload circuit) and led next to the BW symbol.. My dm17s were very similar so i used this as a model for mine. Yours appears to have a schematic available which mine did not. I am guessing your APOC is locked on, in some fashion diminishing the "overload " signal to your woofers. This is possibly the result of a small 100 uf electrolytic cap in the circuit leaking chemicals and creating a short in the circuit. It looks like a lightning strike happened, which probably did not. Pour yourself a stiff one and visit the french site audio heritage dm3000. Right-click to translate.
The mylar caps in the signal path are decent quality and likely do not need changing. Modern silver plated wire soldered to the drivers could be rewarding.( a la Troelsgraveson BW 802).
I read somewhere these dm3000 weigh 75 lbs. Take care and good luck.
P.S. The " electronic delay" appears to be a series of caps and coils on the tweeter circuit separate from the APOC.
Also see about lifting diodes and transistors & R10.
Jerry's B&W 802 S2 Review (1997)
The DM3000 is well worth repair with a superior wiring harness to the earlier dm12/17.
PPS. Simpler but worse;one of the 6 1/2 " kevlar woofers BZ 200 16 ohms. may be on the way out. Should be easier to check that first.
If someone is parting out a dm220 the woofers (and tweets) could sub in a pinch.
I have a pair of DM 3000 I picked up with bad tweeters a few years ago. I ended up swapping them for some from Dayton but I'm thinking about redoing the X-over now. Just curious if you had any luck?
Hello guys …. Long long time . Lot of things happened ( including a pandemic) that led me to put my vintage HiFi stuff in the storage . It’s out now and I will start working on it soon.
Stay tuned
