B&W Matrix 803 tweeter replacement
Longaevus
I hope you guys can give me some guidelines on this one!
I am currently trying to do my best to get a pair of these speakers back to business, they look like they had a very rough life and I purchased them with missing tweeters!!
B&W's original drivers are uber expensive so I have been sugested to try some Swan Diva TN28 units, they are very cheap and would be a perfect way of making sense out of the "restoration".
My question is, will I need to do anything about the crossover?
Freq. Response
Impedance
Won't it be hard to fit a different tweeter into that same housing? Or did you think you would mount them in a different way?
The B&W network is undoubtedly matched to the specific tweeter's response, so it will be less than optimum with a different driver.
Given your limited choices and the cost effectiveness of these ($50 versus $800) I'd just give it a try and see how it sounds to you.
It's likely that the frequency range will be similar (and controlled by the crossover) though the efficiency will probably be a bit different.
If these are more efficient then you could put a L-Pad in there to lower the output.
If less efficient then control the highs with the source treble control.
Right now there is no housing at all, the tweeters are 100% absent, only the cabling has been recessed into the cabinet for future adaptation as I am now trying to do. The example picture is the tweeter assembly as it is being sold right now but there was a stand/mount for it that achieved a perfect fit for a pleasant finish on top of the speaker which is now obsolete and apparently none of the dealers carry it.
Actually the $50 will not be attainable because the first version of the tweeter is discontinued and the revision (as pictured) which is named "TN28II B" will cost about $100 for the pair + shipping costs. At the end of it all I will be asked for $117 delivered and I will have to improvise the mounts for a better look.
To be honest I am not very concerned about overall sound quality as I do not have "audiophile ears" and usually I find most speakers to be good sounding, I lack experience in order to be able to tell the subtle differences apart.
I am trying to understand if other low cost alternatives can be considered, for example:
DAYTON AUDIO 1 INCH - ND25FA-4 ($15)
Here's a picture of the ones I have that I offered you.
As mentioned I'll be in Madrid next week if that makes shipping easier.
I believe this is the current revision, not the first one, which I believed packed the stands/mounts, it will have to suffice I guess, having the speakers in full working condition is my top priority and aesthetically-wise these look the part and are similar to the originals.
