B & W Pics
A general question that I have been thinking about (and have been guilty of).
Does it count if a color image is processed with the color luminance channels taken out? It isn't B&W in the classic sense then. I do not know a way to take a digital B&W. Personally, I consider making a color image into a B&W a cheat. But as I wrote- I do it because of no other option unless I am shooting Pan-X or Tri-X film.
I'm not sure what you mean by "color luminance channels."
If you're asking whether using a black and white mode of a digital color camera, or rendering a file from a digital camera in black and white is cheating, the answer is surely not.
Is it identical to black and white film? No.
Adjusting the relative brightness of gray from different hues in Lightroom (or similar programs) is similar to using color filters with monochrome film but not identical. For example, you can darken blue skies, and get a very similar effect to what would have been done by using a yellow or red filter in film photography. The point is that, as Ansel Adams famously said, "You don't take a photograph, you make a photograph."
A digital camera can be built without the Bayer RGB filter layer, but that is an unusual thing these days, mostly done for laboratory/scientific use, not normal photography. Even when cameras are converted for infrared by removing the IR cut filter, the Bayer RGB filter is not usually removed, as it is too closely attached to the sensor chip. Plus, you would need new firmware in the camera or post processing software/settings.to disable the interpretation of the raw data as RGB. Camera raw processing in software such as Adobe and others assumes the raw data has been subject to the Bayer filter and performs a "de-mosaicing" even before converting to black and white. This allows more resolution in the black and white version than you could get by using a color filter in front of the digital camera, while still adjusting the gray levels to depend more or less on particular colors. However, it is not perfect, as only half the sensor pixels are sensitive to green, 1/4 to red, and 1/4 to blue, so there are bound to be some edge problems when you simulate a deep, pure red or pure blue filter. A true monochrome sensor, like monochrome film, will have full resolution no matter what filter you use.
Think of the digital case as being like taking a picture with color film and then deciding to print it in black and white.I think that's a legitimate black and white picture.
You can also set your camera to black and white, see a black and white preview, and get a black and white jpg image. The raw file, of course, will contain all the color info, but you can also turn that off in whatever raw processing program you are using and accept the default conversion. But why accept the default? To me, adjusting the rendition is just as legitimate as using color filters with film.
All I meant was taking the color image and with post-processing, strip the color channels out to force a b&w rendition. That's what I consider "cheating". Maybe I need to re-think that after processing (pun INtended) your thoughts above.
Cheating? lol!
If you take the color channels (RGB) out of a digital image you have nothing.
