I did test these and the noise went down but, from memory, no more than 10dB. As @Hyperion says, only to be sucked up by the noise floor of the rest of the unit. All that voltage gain to get the big watts out causes a lot of that.
I kind of want to do this testing, just to see, but I have a very strong feeling that I’m just going to be wasting my time. I want to test the Marantz 2325 with the factory BA312 in it. It has been fully restored otherwise, all new capacitors, many films. So it’s not completely factoring. I had some parts delivered today, so after testing with the BA312 I will put in the boards with the original schematic.
Obviously those are the TO92 part numbers, these are what I used.
And then after those use the boards with the low noise 2SC2713. I don’t suspect a huge difference, if at all. Maybe a difference from the original BA312.
But we will see. I’m still very new to the analyzer, I do have to figure out how to do a frequency response and a distortion graph. Basically all I’ve used for is measuring distortion at a given output.
Hopefully I with some results
Dan
