Bad day at work...
Vintage TX
Analog forever
This is even funnier when you realize it's real! Next time you have a bad day at work...think of this guy.
Rob is a commercial saturation diver for Global Divers in Louisiana. He performs underwater repairs on offshore drilling rigs. Below is an E-mail he sent to his sister. She then sent it to radio station 103.2 on FM dial in Ft. Wayne, Indiana, who was sponsoring a worst job experience contest. Needless to say, she won.
Hi Sue,
Just another note from your bottom-dwelling brother.Last week I had a bad day at the office. I know you've been feeling down lately at work, so I thought I would share my dilemma with you to make you realize it's not so bad after all. Before I can tell you what happened to me,I first must bore you with a few technicalities of my job.
As you know, my office lies at the bottom of the sea. I wear a suit to the office. It's a wetsuit. This time of year the water is quite cool. So what we do to keep warm is this: We have a diesel powered industrial water heater. This $20,000 piece of equipment sucks the water out of the sea. It heats it to a delightful temperature. It then pumps it down to the diver through a garden hose, which is taped to the air hose. Now this sounds like a darn good plan, and I've used it several times with no complaints.
What I do, when I get to the bottom and start working, is take the hose and stuff it down the back of my wetsuit. This floods my whole suit with warm water. It's like working in a Jacuzzi.
Everything was going well until all of a sudden, my butt started to itch. So, of course, I scratched it. This only made things worse.
Within a few seconds my butt started to burn. I pulled the hose out from my back, but the damage was done. In agony, I realized what had happened. The hot water machine had sucked up a jellyfish and pumped it into my suit.
Now, since I don't have any hair on my back, the jellyfish couldn't stick to it. However, the crack of my butt was not as fortunate.
When I scratched what I thought was an itch, I was actually grinding the jellyfish into the crack of my butt. I informed the dive supervisor of my dilemma over the communicator. His instructions were unclear due to the fact that he, along with five other divers, were all laughing hysterically.
Needless to say I aborted the dive. I was instructed to make three agonizing in-water decompress ion stops totaling thirty-five minutes before I could reach the surface to begin my chamber dry decompression.
When I arrived at the surface, I was wearing nothing but my brass helmet. As I climbed out of the water, the medic, with tears of laughter running down his face, handed me a tube of cream and told me to rub it on my butt as soon as I got in the chamber. The cream put the fire out, but I couldn't pxxp for two days because my butt was swollen shut.
So, next time you're having a bad day at work, think about how much worse it would be if you had a jellyfish shoved up your butt.
Now repeat to yourself, "I love my job, I love my job, I love my job"
:yes:
Here's one that I always loved about having a bad day...
Enjoy...
Dear Sir:
I am writing in response to your request for additional information in block #3 of the accident reporting form. I put "poor planning" as the cause of my accident. You said in your letter that I should explain more fully and I trust that the following details will be sufficient.
I am a bricklayer by trade. On the day of the accident, I was working alone on the roof of a new building. When I completed my work, I discovered that I had about 500 pounds of bricks left over. Rather than carry the bricks down the stairs by hand, I decided to lower them in a barrel by using a pulley which was attached to the side of the building at the sixth floor.
Securing the rope at ground level, I went up to the roof, swung the barrel out and loaded the bricks into it. Then I went down to the ground and untied the rope, holding it tightly to insure a slow descent of the 500 pounds of bricks. You will note in block #11 of the accident reporting form that my weight is 182 pounds.
Due to my surprise at being jerked off the ground so suddenly, I lost my presence of mind and forgot to let go of the rope. Needless to say, I went at a rather rapid rate up the side of the building.
In the vicinity of the third floor, I met the barrel which was proceeding in a downward direction at an equally impressive rate of speed. This explains the fractured skull, minor abrasions and broken collarbone, as listed in section 3 of the accident reporting form.
Slowed only slightly, I continued my rapid ascent, not stopping until the fingers of my right hand were two knuckles deep into the pulley, which I mentioned in paragraph #2 of this correspondence.
Fortunately, by this time, I had regained my presence of mind and was able to hold tightly to the rope in spite of the excruciating pain I was now beginning to experience.
At approximately the same time however, the barrel of bricks hit the ground! The bottom fell out of the barrel. Now devoid of the weight of the bricks, the barrel now weighed approximately 50 pounds.
I refer you again to my weight in block #11. As you might imagine, I began a rapid descent down the side of the building.
In the vicinity of the third floor, I met the barrel coming up. This accounts for the two fractured ankles, broken tooth, the severe laccerations of my legs and the lower body.
Here my luck began to change slightly. The encounter with the barrel seemed to slow it enough to lessen my injuries when i fell into the pile of bricks and fortunately only three vertebrae were cracked.
I am sorry to report, however, that as I lay there on the pile of bricks in pain, unable to move and watching the empty barrel six stories above me, I again lost my composure and presence of mind and let go of the rope.
Scott
That brick story is a classic. It's been set to music in an "irish tale" type of song by Mike Cross and probably others.
The name of the song is Dear Boss. Its all over those illegal download things.
Not that I would know anything about that. :D
