Bad Headphone Socket
Jay Kay
Well-Known Member
i have a Rotel RA930AX integrated amp. Bought new in the mid 90s. It’s a great amp and I’ve had it serviced a couple of times. I’ve noticed that my headphone socket is bad, just moving the headphone jack a bit will make the sound cut in and out, not completely, just loses the low end. Thorough doses of Deoxit have not changed the situation.
A fellow on YouTube makes it seem like it could be just a simple matter of opening up the amp and hitting the connection points of the socket to the board with a bit of solder. I was interested in doing it myself instead of my service guy as I just didn’t feel like handing it off or dealing with him in this Covid challenged time.
I’ve scrounged around the web quite a bit including this site but haven’t found too much information about this problem. Does the YouTube fellow’s ideas sound like the thing to try? I haven’t even looked under the hood yet to see if the headphone socket sits like the example on YouTube, but I am anticipating that it may be similar.
Would appreciate very much anyone weighing in!
Definitely sounds like a loose solder joint. However, if you have small children, take a flashlight and look into the socket just in case there is something in there. Could also be a spider that decided to make a new home in there too!
The socket may or may not be easy to get to after you take the case off, depends on the design.
Ok, I'll check for those conditions! Thanks for the reply!
