Baffle size for prototype open baffle
Stratomundo
Hi everyone, I have a pair of old 5" Onkyo drivers that sound somewhat full range. After seeing the open baffle epiphany thread, I thought these little speakers might work for an experimental open baffle project. I'm familiar with the sound of open baffle guitar amp speakers, but not open baffle hi-fi. I'm hoping these might give me an idea of what an open baffle stereo speakers sound like.
What would be an idea baffle size for these drivers? 12" x 10" or so? How should they be positioned? I'm assuming centering them is bad idea. Any advice is appreciated!
JE Labs model in cardboard or foam board to see how they sound. Don't expect a lot of bass.
I'm not too worried about bass response at this point, it's just an experiment to get an idea of the open baffle sound. I see JE Labs has a chart for the required baffle length to reach a certain frequency, I should be able to determine adequate dimensions from that.
Good question, have a ton of leftover HTIAB speakers that could be recycled into multi-driver OBs...
I've also been intrigued by the idea of an open baffle line array.
With a single driver not designed for OB's the sound can be very thin and unlistenable.
Then just grab a piece of cardboard and cut a hole. This will give you that idea. If you fret about dimensions right now, on a piece of cardboard than your going to procrastinate on it the rest of the year.
Haha yep you're probably right; might as well try it and hear what happens. I think I've got the gist of how big the baffle should be now.
Well I finally got around to making some prototype baffles for these drivers. I probably should have put this in the open baffle epiphany thread, because I'm surprised by how good they sound. The imaging is really focused, and there is a good amount of detail. They're definitely shy on bass though.
I based the baffle on a scaled down version of the JE Labs baffle mentioned earlier. Now I need to build a real two-way design with a good full range driver and a big woofer!
