GuyNoir
Hallowed State
At this point, I don't think my output tubes can be trusted. I found two 6P14P-EV spares and put them in the left (humming) channel. They balanced up nicely and the hum is negligible..much quieter than what I had in there. And now having jogged my 256k memory, I remember swapping from two pairs of quads to find the quietest four earlier this summer. I remember being able to make the hum go from left to right by swapping outputs from side-to-side. So, if these are still quiet by morning, I guess my only remaining issue then would be the channel imbalance.
Edit - NOPE - left channel buzzing already.
Do you mean center terminals at 9 and 3 o'clock jumpered together?
Quick and dirty check, take a jumper wire and clip the two center terminals of the volume control together. If the imbalance remains, the problem is in the power amp section. If it goes away, its somewhere between input and volume control.
Edit: Still doesn't like straight AC line voltage - left channels still hums there. Seems content at 115v. For another day.
