Balance Control Pot solution?
Jock Strap
jacksonsinliss
Restoring vintage HiFi amps usually involves replacing the Balance Pot? Unfortunately, these centre-detent pots that provide zero resistance in the centre position are virtually unobtainable.
I had an idea... how about using a many-way, make-before-break, 2-pole switch instead? A suitable array of resistors to provide stepped attenuation of each channel would keep the control without losing all of its functionality?
It's an expensive solution so I have not yet tried this but I wondered if anyone else had used such a solution. The method I have used so far is to replace the pot with two resistors to effectively remove it from the circuit. I then leave the pot in place but not connected to retain the appearance.
I've run into this in the past year or so and after searching, I did the two resistor fix.
I see what you're saying regarding a stepped balance, but it would seem that more than a two pole switch would be required since you still need that 4th leg that's on a balance pot. I haven't really thought through it, but the concept seems sound.
Good luck with the project.
Excellent idea. Some amplifiers have used stepped attenuators for volume control and McIntosh used stepped attenuators for tone controls. The downside is that rotary switches are EXTREMELY expensive, especially 2 pole, 24 or 36 position for a volume control. A balance control could probably have fewer steps.
