I have a couple questions regarding the balance pot on this amp.
"Does your amp have a balance pot? If not, it needs a pair of 390 Ohm resistors to sub for that (some versions had the pot in the amp, some in the tuner)."
Mine has the balance pot in the Tuner well except its not marked balance see pic. It says meter zero. I assume this is it?
If this is the balance pot would it be better to use than the resistors?
Also, it will fill that empty hole in my chasis where the balance pot would go except its missing a knob to turn it with.
