So it's safe to say that I'm a press smashing Luddite but I'm trying to accept the future.. I've heard about this new technology called 'active xovers' so I picked up a DBX Drive Rack PA to check it out..
I pulled the 604 out of the UREI monster boxes and wired them to some Duelund 12ga tinned copper leads, plugged those into some amps using some XLR to RCA Neutrik adapters because me no havey XLR cables in wide supply.
So I plugged it all in and amazingly, and as a testament to DBX Engineering, I was able to fumble through the iPad UI wizards and get everything set up.. I even figured out the DIRAC mic room correct, without cracking the instructions.. which elevates me to the knowledge based version of a Red Shirt extra on Star Trek.
Crossover??!
oK, i'VE started to read about crossovers but nothing is really making much relatable sense.. while I'd like to learn all this 'junk' I'd rather just get it set up now and backfill with understanding at a later time.
If anyone is familiar w DBX crossover or just general settings for either the Tannoy HPD 15 or Altec 604-8G please share here so I can fiddle, fumble and forge a path forward here.
Pretend I know nothing (which should be easy for both of us) and let's start from there.
Crossover??!
