Is this the speaker? If so their is nothing better than the spade connector.
...After rebuilding the crossovers on the Wharfdale W35’s I was reacquainted with just how good, and simple an old school sold brass screw with a Thumb nut is. For the $50 bucks one pair of Cardas binding posts costs you can purchase enough copper screws, bolts, and thumb nuts to refurbish a bunch of speakers with a connection that is every bit as good as anything no matter the price.
Of all of the banana plugs I have used this is the best design. I use them on the vintage test equipment I have which uses banana plugs for the test leads. They work particularly well with sockets that are worn from years of use.
Okay. You asked for opinions, so here's mine. I would not use plated brass for any kind of connector, be it a banana plug or rca. I prefer gold or silver over copper, and my personal experience is that there is a pronounced difference in sound with plated copper vs plated brass. Once again, my opinion and experience only. I have no scientific data to back up these statements. I started out with cheap plugs, including some I got at Lowes or Home Depot that resembled the better monoprice offerings with dual set screws for the wire retention and was dissatisfied with all of them. Just my .02 BTW those plugs you showed should work fine with your wire.not sure these will work with 16 gauge wire (16 AWG soft "loud speaker cable" from monoprice), what is your opinion? thank you. (referring to https://www.madisoundspeakerstore.com/banana-plugs/plugs-bp-sz-single-banana-plug-red/)
Good Stuff I use the Monoprice 12AWG cable. I have transitioned to KnuKonceptz Kord Kable 12 Gauge Copper Speaker Wire a little more expensive but marvelously flexable very good insulation.not sure these will work with 16 gauge wire (16 AWG soft "loud speaker cable" from monoprice), what is your opinion? thank you. (referring to https://www.madisoundspeakerstore.com/banana-plugs/plugs-bp-sz-single-banana-plug-red/)
