audiodummy
Well-Known Member
I have a B&O SP-12 cartridge and stylus and it was acquired broken. This is for a Beogram 3000 but I forgot the exact submodel, thinking it's 5211.
The cantilever seems to be permanently attached into a cross shaped piece of metal that's apparently permanently stuck inside the "stylus replacement unit" which includes the top plastic shield and a metal shield that goes around the cartridge - which has four prongs that seem magnetic. When I slide this unit over the cartridge, the cantilever still seems very limp and collapses under the weight. I'm guessing the magnetic field on the prongs should sort of attract the cross shaped piece of metal, somewhat strongly, so that it won't collapse under the mass...
How strongly should the cross be attracted to the "magnetic" prongs? Should they "touch" that cross that the cantilever attaches to?
Based on this information, is this cartridge/stylus unit repairable? Should the prongs be magnetic? How strong should the magnet be?
I can't seem to find much info about this, best I see is https://www.vinylengine.com/turntable_forum/viewtopic.php?t=16930 ...
Thanks!
Thanks!
