Barn find TA-800, tips?
Bill_0531
Got this barn find TA-800 today, and its looking pretty rough. I've worked on multiple tube tape recorders before but never a receiver.
missing all its tubes, knobs, cabinet and possibly more.
The top side looks pretty bad with possible water damage and rust. luckily all the parts that should move moves.
The bottom side looked fine actually, no water damage and pretty clean, although I assume all caps have to be replaced.
what are the bare minimum tubes that I need to test it's functionality? I only need the preamp and phono preamp to work, no power amp and no radio.
I need some assistance in routing the tuning wires, and the AM one has snapped and the FM one isn't functioning correctly, need a list for caps I need to buy too.
Any tips would be greatly appreciated!
Congrats on the discovery .. Yours looks to be in worse shape than this one (a 400) that a neighbor wanted to get rid of .. ...
Fortunately, the electrons don't care that much about the rust ... I am glad it has a wood case
As for caps and tubes service manual can be found in this thread
You need the power amp to work if you want to do anything useful with it. There is no preamp output, and there is no buffer so even if you added one its high impedance and not overly well suited to drive most things. Also without the load of the power amp the voltages are going to be way off where they belong elsewhere.
7199 tubes, 7591, and all of the 12ax7 will get all of the audio bits live.
Thats good to hear. I have some 12AT7s left over from my tape recorder projects.
Depends what it is. If its silicon, probably not, selenium would be a good thing to change. I don't know the TA-800 deeply. The TA-600 I have uses the same tuner and preamp stuff, but the power amp is different and I have two tube rectifiers. I don't think this uses a tube rectifier.
It's got a selenium rectifier. Thanks for the tip.
