Basf d-6075 ***wow!!***
releone71
Basf d-6075 integrated ***wow!!***
For all the integrateds lovers here is a real gem!!:thmbsp:
I purchased this unknown black amp years ago from eBay Germany for cheap money and stored it in the shelf having no time to give it a try. I recently opened the case and found out a real great piece of equipment: Alps pots, Rubycon electrolitycs, dual mono topology with power supply for each channel and a really rational layout as for wires and boards. After the usual cleaning operation I hooked it up to my Proacs: good dynamics and soundstage, tight basses, airy highs, a rigorous performance. No regrets even in comparison with modern amps, to tell it short. And it has a good phono section too!!
I've been lucky to accidentally put my hands on a full working unit but, if you find one of these amps around the web, I strongly recommend to catch it even if it needs any little reparation. It is worth the time and money you will spend. Anyway, be aware they were/are not so common therefore they are hard to find but usually sell for a few bucks.
Finally, I was told they were NECs AUA-8000E built by BASF for the European market and obtained excellent remarks and a solid 10/10 as for manufacture quality in a comparison between several integrateds in a 1978 Stereoplay issue.
So don't miss out this gem!!:tresbon:
A few pictures...
Well, you know what comes next.
Hmm... only four posts, so maybe you don't. So: :worthless
And welcome to AK, by the way.
eheh...I know I know...just the time to resize the pics...:D
Note the perfection of the solder joints in the picture of the driver board!!
On the pictures of your amp it seems that the vu meters are dead. Exactly the same on mine. In fact the background serigraph of it isn't made of paper but aluminum. With time, the glue that hold it failed, and the alu plate falls on the needles. On mine, it even had a guillotine effect - the vu meters are completely dead. I am looking to find replacement parts - but not an easy job !!!
