Poskok2010
Member
aka NEC AUA-8000E aka MCS3865.
Found two similar treads:
https://audiokarma.org/forums/index.php?threads/help-with-idle-current-adjustment.578811/
https://audiokarma.org/forums/index...rent-question-nec-aua-8000e-amplifier.893200/
but with no solution, couple of guys tried also to revive the treads with same problem, so i assume that is general issue with those amplifiers.
Anyway just after a startup on test points (two per channel) i have on: Right Ch 1,8mV and 0,9 mV
Left Ch 1,2mV and 0,4 mV
after one hour of amplifier idling i get:
Right Ch 11mV and 10mV
Left Ch 8mV and 4 mV
here is a pic of schematic with my measurments in green letters (red are original values)
https://ibb.co/s2LCdvy
just load full resolution and after right click on it save as.... and watch it in full size.
All voltages are almost ok except the rails to power transistors. They should be +/-42V but they are in real +/-46,4V on right channel and +45,7V/-45,9V on the left one. I assume that also the voltage on D203 (lover 10% than rated) is messing with idle current.
Somebody on another thread mention lazy outputs. How can i test their laziness
Any other ideas or suggestions?
Will be very grateful on any help, thanks.
