JoeESP9
ESL's & tubes since 83
The problem with "naked" venetian blinds is they are inherently reflective. This can be somewhat mitigated by adjusting the slant of the slats. However, IME the combination of heavy curtains and blinds offer the most effectiveness and flexibility for room correction.
To properly treat a bay window's acoustics you need a combination of absorption, diffusion and even some reflectance. Usually, you'll achieve better results if you treat all of the room surfaces, especially first reflectance points. Bear in mind, the idea is to make the room friendlier to balanced sound. An anechoic chamber or totally soundproof room is not the goal. Once I got the right settings for window, curtains, blinds and other devices (absorption, bass traps, etc.) the soundstage became deeper and wider.
Unfortunately I can't adjust things for the best all the time. My best setting requires the windows to be open. That's not an option in the winter.
Then there is the LEDE (live end dead end) room. For this you damp the entire end of the room where the speakers are located. It's only valid when using "monkey coffins".
