Beautiful receiver in need of replacement toggle switch
rdwinal
I picked this beauty up at a thrift store in (almost) mint condition for only $20. The only problem - a snapped toggle switch.
It's a Toshiba SA 504. Does anyone know where I can get a new switch and switch cap?
What I have done before is take a very small drill bit and drill into both the switch and the broken off toggle trying to get in the dead center of both. Next find a piece of metal that will fit in the holes (I used a finishing nail that I cut to length). Test fit to make sure it the right length, glue it into the switch and let it dry, and the glue the toggle onto the stud thats glued onto the switch.
The one I did was the metal shaft on a pot and it was hard as hell to get it centered but it worked well, good luck :D.
1 plus on that idea.You could also use a plastic or wood dowel and do the same with epoxy cement or the likes.
I did this to repair the counterbalance arm of a turntable that broke off during shipping, still holds to this day!
