H2s04
auralmicitisis
Hello all,
I've been trying to find the gumption to post about this for a few months now. It started in March, telling myself that when summer came, I could finally get to work on a restoration project, and actually finish it. Well, summer has come, and I've procrastinated until the end of July by telling myself "I'm not ready yet" and other excuses of the like. Anyway, I thought I'd just get that out of the way first :yes:
I'll be honest; my history with restoration has been very spotty, filled with mediocre successes and poor refinishing jobs, mostly due to misinterpreted advice from other forums, and poor planning on my part. So, with the acquisition of a Bell 2122 tube amp last october, I decided that I couldn't live with it in a non-functional state sitting atop a RTR deck. I also have a strong desire to experience tube audio in a personal setting, so this little amp is a great start for someone on my budget.
To continue, I've never been very good at finishing projects I start, mostly because I always seem to hit a wall when things get complicated, and I feel like I'm just too young to be working on such old pieces. With that in mind, I want to set out VERY SLOWLY on this project, trying to gather as much information and help as I can along the way. I know that you guys are VERY understanding about such things, and some of you should receive medals for what you've had to put up with on this board in the past :lmao:. I realise I should I have started this earlier, but lets face it, I'm a little shy :scratch2:
Okay! Now, on to the technical stuff.
My restoration experience includes the following: replacing capacitors in several vintage radios, replacing electrolytic capacitors in an early 60's RCA table-top television set, and a complete tube replacement in an already-working Eico HFT-90 FM tuner. The FM tuner works perfectly, but needs a new volume potentiometer because the integral on/off switch broke in the on-position (luckily) during operation recently.
Eletrolytic replacement went OK, but the picture was poor, and I decided that I just didn't know enough yet to pursue the matter any further.
And now, the major issue: paper capacitor replacement. After replacing capacitors in each radio (both slightly worked prior to the application of my "expertise") both exhibited the same symptoms: a loud 60 Hz humming noise, and one would continue blowing tubes. No responce to tuning; nothing. I took extreme caution when working on each set, making sure each solder joint was done perfectly, and solidly. I also checked each resistor prior to the post-operative first run. So, I'm in a fog here now
You can probably see now why I'm taking so much precaution before I set out to restore my Bell 2122 amp. I want to go at it as if I were completely new to the scene, making sure I triple check each direction, and ask as many questions as possible. I just hope you guys (and gals) will be able to put up with me :sigh:
Now, I want to go every thing that I should do before ordering the capacitors I need, and also, what type of capacitors do I really need?. I've seen people using metalized polypropylene, polyester film, orange drop, and the like. I have no idea what capacitor is right for which job, and which capacitor is which beneath the chassis (except for eletrolytics, I'm comfortable with those by now :thmbsp: ). To note, I used metalized polypropylene film capacitors in both radios that failed; was that an incorrect move?
I'm planning on purchasing a tube tester on ebay, and I'm in a bit of a fog as to which one I should get, so if anyone could help instruct me with that as well, it would be a great help :yes:
If anyone has a schematic for this particular amp, it would prove to be a great asset while working on this project, I'm sure. Can someone tell me the bulb voltage as well for the indicator lamp? It just needs to be replaced
Again, I would just like to thank everyone on AK for the help they have given me in the past, and I hope that this project will work out better than ones in the past :yes:
