I have a hum that I can't get rid of, and I've tried everything. Here's the set up:
Technics SL-1800MKII
Bellari VP130
Grado Black
Shure M97xE
To keep things simple for troubleshooting, I moved only the TT and the Bellari into my office where I have a brand new electric line going straight to the fuse box.
On the TT, I opened it up and ran a piece of speaker wire as a 2nd ground cable to the metal plate in the inside (the original is grounded there as well). I also soldered in a new set of RCA cables since the old ones were getting funky.
I've tried every combination of grounding that I could think of with the two ground wires (the Bellari has a headphone jack, by the way, in case you're wondering how I'm was listening to the hum...). The directions for the Bellari recommend that you run them both on the same circuit. It seems that the only way I can reduce the hum to a very low level is by running them on separate circuits.
When I finally reduce the hum a bit, I start picking up radio stations. I've also tried to troubleshoot the problem while it's hooked up to my system. Nothing else actually has a ground knob, but I've tried every screw I could- nothing.
To check the TT, I wired it to a Kenwood preamp that actually has a built in phono stage and it was dead silent.
Unless someone here has been through this and can offer some advice, I guess I'm going to have to send it back. I'm not looking forward to searching for something that's comparable at that price range :scratch2:
If anyone has any insight at all, I'd greatly appreciate it- I love a good mystery, but I love find solutions even better!
Thanks in advance,
-Phil
www.philpalombi.com
Bellari VP130
Grado Black
Shure M97xE
Thanks in advance,
-Phil
www.philpalombi.com
