avantbored
Hi all,
Many thanks to all who posted in a previous thread of mine helping me diagnose a speed clutch issue. While I've yet to work on that, I did replace the suspension, which was a big level-up for this newbie like me.
Relatedly, a new issue has presented itself. After having replaced the suspension with a kit from Dave at Vinyl Nirvana, I've noticed a rumble/shake/grind (not sure on the adjective best to describe the sound) upon firing up my table. I've included a video to help contextualize the issue. With the platter inverted, you may notice the belt tripping slightly on the bottom part of the pulley. The aforementioned noise is also audible.
Some other technical context:
- This is a Thorens belt purchased from Vinyl Nirvana. During suspension cleaning, I did a quick wash in lightly soaped water (eco organic dish soap blah blah).
- Also during the suspension service, I used about two Q-Tips, reasonably soaked in 99% rubbing alcohol, to clean the area on the sub-platter where the belt grips.
- Not sure if it is the belt, but that is my amateur guess.
Is this a common issue? May this be mitigated with adjusting the azimuth? It doesn't really affect playback at all, though it does produce some unsightly shaking in the arm board, and hence the arm itself when loosed from its catch. Using the most-downloaded "RPM Speed and Wow" app on my phone (I know it's not the most exact!), I'm registering about 33.24 rpm, and my ears can't hear any noticeable difference.
Thanks all for your time and attention, and I hope you all safe and sound.
Here's the video:
Here's the video:
