I have an entry level Benz Micro cart (MC20E II) and am considering taking the upgrade deal from Benz and moving to an Ace or Glider. Any thoughts on these carts vs. moving to another brand?
My table is a Yamaha PF-1000 and I mostly listen to rock from the 60's and 70's.
Thanks!
Dog
Dog, I would say it would depend on a couple of things.
One, is what will a Benz Dealer give you for trade-in allowance for your Cartridge? This value "should" be a stardardized value, meaning all Benz Dealers will give you the same amount.
The variance that there can be, is now, how much are they willing to take off the List Price of the new, better Cartridge. Here, there is a difference depending upon who you call, and ask.
I found this out myself.
If, the Cartridge you are trading, is not destroyed, and has lots of life left in it, this could be a tough choice, the difference of what you paid, versus its trade-in value?
OK, then let's move past this part. Let's say you decide you wish to go for the "gold", and go with the Benz Glider. I'm taking an eduacated guess here, but I believe the new S-Class Glider is $1,000 list?
(I understand the new version Glider's now are fitted with the Fritz Gyger Stylus, such as what comes with the Ruby 3, or Flagship LP Cartridge).
In defense of Benz, and let's say the Glider, you can get this Cartridge in 3 different output levels, so this particular Cartridge may hold an advantage for you, in being that you can ideally match the Cartridge to your Phono Stage's Gain, and Loading capabilities, you don't have such freedom with other brands-models of Cartridges.
But, let's take the other side of the coin in a hypothetical scenario. Let's say your Benz is worth $150 in trade for another Benz. This $150 may, or may not be worth its influence over you? At this roughly $1,000 price tag, there are of course other worthy Cartridges in this price arena, let's say an offering from somebody like ZYX?
This is of course a choice you'll have to decided on?
It would be a choice that would be tough for me to make, and the difference of the $150 might not be enough to persuade me to go again with Benz.
I owned the original Hi-Output Benz Glider for a good ten years when they first came out, back around '97. It was a darn fine Cartridge, superb tracker, tracked anything I ever threw at it, gave good sonics, and an enjoyable sound. The new version should be even better sounding.
Benz's are said to be "warm" Cartridges, but I think this is a slight misnomer to say. I think a more accurate term would be to say, in comparison to some other hi-end offerings, the Benz might display a bit more Bass Bloat. And I would assume this also means that most Benz Offerings are not what I would call "analytical" Usually the higher you climb the "Benz Ladder", the better the refinement, in areas of smoother, less grainy sound. Midrage is usually very good, lush, pure, toneful.
I personally noted this change-difference when I moved up to the Ruby 3.
But let's take the Glider, against such a Cartridge as the ZYX Yatra, or Fuji. These Cartridge will more than likely offer quieter play in the groove, be a faster sounding Cartridge, will display less Bass Bloat, but this doesn't at all mean "Bass Lacking". generally what it will mean is tighter, more accurate Bass response, and no over-emphasis of Bass.
Do let us know what sort of offering you are able to get. I'm sure others here would be interested in knowing, and perhaps with a bit more known, you can then be a better judge of what course to take. Best of luck, Mark
