david winter
Classical music lover.
Hi,
I've been working on a 4002 type 5511 which played records fine until the arm lowering stoped.
Since, the Up/Down button no longer acts on the arm.
The main board is recaped, trimmers replaced, carbon resistors checked etc. I have 20.8V after 1IC1.
While checking the arm switches, I noticed that if I very quickly pushed the arm's "end of return" switch, the arm would sometimes lower.
In this case, pressing the Up/Down button will lift it, but the arm won't lower.
As the issue is clearly not on the keyboard side, it's somewhere in the circuit which enables the solenoid when the pulse is detected, but probably not in the part which disables the solenoid.
Any hint appreciated. Thanks.
