I have a full distortion from right channel.
From the voltage and signal trace I did I discovered that there is no output voltage and signal from 496 diode.I changed the diode but still nothing
I swapped the transistors tr45 46 47 50 from the other channel but still nothing.
I swapped the input signals cables which goes to amplifier pcb and again nothing changed
I put new power supply capacitor and didn’t do anything
Tr46 has voltage on emmiter and base but not in the collector
Here is the schesmatic marked with no output
I can’t find any solution to my problem
Any help would be appreciated.
Thanks
Thanks
