hi swechsler,
many thanks for your reply and for the welcome. i am a total newb but, having read around on the issue, realise that there is a lot more to changing a woofer than simply finding one the same size and dropping it in. in addition, from what i've read, the beovox s45-2 don't have a mid but a crossover that fills in between the woofer and the tweeter (not sure i really understood how this works and what impact this has on the woofer but it's what i read).
i don't have a multimeter unfortunately but, if i changed both woofers, and if the stated tolerance is 4-8 ohms, would it matter ?
i have looked on anibis.ch, ricardo.ch, tutti.ch, marketplace, ebay, amazon and many other sites but nothing second hand unfortunately.
i have taken the woofer out and looked at the superficial aspects and haven't found anything obviously wrong. i have read about issues with this particular speaker where the glue has become loose and the magnet has dislodged in transport however, i see no evidence of this superficially. having said that, i am a newb so wouldn't know what i was looking for.
i have tried to see if the rub is on one side only, to see if inverting the magnet will compensate for any droop due to time. however when i push the paper cone in, it appears as if the rub is all around and not only on one side of the speaker.
based on the size of the speaker (more info here :
https://www.beoworld.org/prod_details.asp?pid=666) i was told that the Goldwood 8024 or 8028 would be fine however these are not easily available in europe and was hoping someone would be able to propose an alternative... again i realise that it's not a simple issue !!!
in any case, if anyone can help i would be deeply grateful as these are beautiful speakers and the one that works has a sound that i really like.
best regards,
jonathan
