Best 12AU7?
In what, amp, preamp? There is no best, but if we knew what your piece of equipment was, then maybe someone would have a recommendation.
jeff
IMG_0341.jpegIt’s a Hagerman Baritone Tube Buffer. It came with a Mullard reissue 12AU7. I’ve also been using a Tung Sol re-issue 12AU7W. I tried a RCA clear top (grey plates) and it sounded too warm/fuzzy.
That unit is supposed to sound warm and fuzzy. That's why it uses a 12AU7 in common cathode configuration. A real tube buffer - which by definition will exhibit little or no gain - uses a cathode follower or transformer output stage.
Jack
Jack
Can you provide an example? What about the Musical Fidelity X-Can 10D?
well, if the two 12AU7 tubes most known for high end extension, sparkle or clarity don’t offer u some of what ur lookin for, then maybe those characteristics are of the device your usin.
what did hagerman himself
Say?
What is the best 12AU7 or equivalent? NOS or new production. I like brighter sonics with good treble air. Thanks!
not sure best is a great descriptor. If you want brighter sonics you may want to consider the RCA clear tops, or for more brightness on top the PSVANE 12AU7-T II. Another option you can consider is adding film bypasses to the main power supply caps. As an example a .1uf + a 0.01uf film cap will add a lot of air and openness to a unit.
I haven't researched the market for these products, but that wouldn't be my choice. Two common-cathode gain stages in cascade is an unnecessary amount of signal processing. The unusable level of gain created by this approach and less than optimum output impedance is controlled in this particular design by a substantial amount of NFB between the two stages. It's similar in this regard to the Blue Velvet preamp of years ago. If we're really discussing a buffer - not a preamp - all that's really needed is a simple, low-loss cathode follower with an input attenuator. This approach creates the shortest possible signal path, no inversion, and it maintains both transparency and speed.
Jack
