GuiteLectric
Hi folks!
First post here
I need to replace the needle on my Technics SL-Q202. The cartridge I have right now is an AT-10 and it sounds a little thin to my taste, so I want to change the cartridge. The two contenders are the AT95e and the Ortofon M2 Red. My main concerns are:
1-The amp vs nominal output of the cartridge. It’s a 5W RH84 with upgraded transformers. The output of the AT is 3.95mV while the Ortofon is 5.5mV. I guess the Ortofon is better since volume might be an issue? In comparison, the AT-10, at 4.5mV is quiet compared to my CD player.
BUT
2- Nominal output vs phono preamp. My preamp is a Cambridge Audio 540p and in the spec sheet it is said to have a nominal input of 3.35mV and 39db of amplification. Can the Ortofon overload the preamp?
Thanks for your help!
First post here
BUT
