Josh Simpson
I know with this table I'm limited to a p-mount, but I might as well get the best one I can find. As someone who is still fairly new to this, I could use some help.
Thanks.
Thanks.
At the high end of the price range, as far as currently-produced p-mount cartridges go, you can get the Grado Gold1 as a p-mount. Grado cartridges can have shielding issues that cause them to hum in some Technics direct drive turntables. I'd be certain that it would work with your SL-QD33 before spending around $220 on one. The Grado line includes 5 other p-mount models ranging down to $60 for the Black.
Another option would be the Ortofon X1-MCP, a high output moving coil p-mount that I have been impressed with. I think it lists for under $200. Your Kenwood preamp should be able to handle the slightly-lower output volume.
At the other end of the range, Stanton and Shure still make one p-mount model each, both with rather basic stylii, positioned at the bottom of their product lines. Both can be improved with stylus upgrades. The Audio-Technica model already mentioned is often mentioned as a good buy, with nicer line contact or Shibata stylii also available.
If you are willing to look at used or new-old-stock cartridges, perhaps with new replacement stylii, your p-mount options can open up. I've done this quite a bit (I have a collection of around 50 p-mount cartridges) and could give you some pointers if you wanted to start looking at used cartridges for sale or auction online.
You've been very helpful. Thank you. I wasn't sure how high of quality I could go with my particular turntable, but from my $30 Audio Technica cartridge, I'd like to build on that a bit, as even with my modest equipment I think I can make some improvements.
No problem. Someday when I get around to it, I plan to write up a guide to p-mount cartridges.
The more I think about it, upgrading the stylus on your $30 cartridge to something like this -- http://www.turntableneedles.com/Needle-213-DHE_p_3820.html -- would get you a good upgrade in sound quality.
Do you have a copy of the LP of Doppelganger, that's in your avatar? I have Vox Humana & Fearful Symmetry on vinyl, and the CD/book set of the whole Alarma Chronicles.
For a newbie, is upgrading a stylus pretty easy? For the record, the cartridge I have is an AT3482p
I've got an AT-331LP on an SL-Q303 (very similar table) and it works very well. Very quiet and tracks great. Highly recommended!!!
I have a SL-QD33, with an AKG cartridge, in excellent condition, however, one channel is missing. I've examined the inside of the turntable and all wiring appears to be in place. Any suggestions other than to try another p-mount cartridge?
