Best cheap speakers for Eico HF87
Alucard
Hello. I have got my Eico HF 87 up and running and I was wondering what the best cheap speakers would be for it
I was also wondering if I should just buy new maybe ?
I heard that there were some really good bookshelf speakers out there for good prices
I don't know. You mostlikely know more about this then I do
A pair of W90C's or W70C's should work well with that amp. Should be able to find a pair of either for well-under $500 with some looking. You could even go with early W90's or W70's if you're not planning on cranking the things (The early ones like I have are only rated for 30wpc, but I'm currently driving mine with a 39wpc Sansui 2000x). All these models LOVE tube power. If you're looking to do the warm, engaging, musical, tube-powered thing, these are a really-good choice (My W90's are phenomenal with tubes). And the Wharfedale W** and W*** models are designed to work well in the smaller rooms found in apartments, duplexes, etc., so even the big W90's will do fine in a fairly-small room (I have mine in a 14'x14' room, and they sound fantastic).
Even the W60's should be okay with that amp (and might be better for you if you need a smaller speaker (The W70's and W90's are kinda' big). Like the others, the W60's are excellent with jazz, classical, and blues, as well as '60's and early '70's R&B, funk, classic rock, etc. They have a very-rich sound with great mids (and also a nice upper-bass response... Not boomy at all... Low-bass is on the lean side, but you won't miss it unless you're listening to music that accentuates those ultra-low frequencies... The nice upper-bass really makes up for that).
You might also want to look into the W3 and W4 models. Sound-signature is similar to the original Airedale model, only smaller.
I am going to start looking for those then thank you very much
Those are a good place to start if you're trying to keep the budget reasonable (Put it this way, I paid $450 for a pair of recapped early W90's in really-nice shape, so under $500 shouldn't be any problem at all... Just a matter of finding them locally because they're not the kind of speaker you can ship... Even the much-smaller W60's are over 50lbs each, and that would surely put the shipping cost at or above the cost of the speakers).
The sound of those early W models is a lot like the Rudy-era Bozak sound. It has that same kind of ultra-musical sound with great mids. A real "you are there" sound. My W90's are ported, but they have a fat, smooth, effortless bass-response that goes really-well with just about anything you throw at them. The tweeters are very-soft on top, but it's perfect for '60's and early '70's music (Beatles, James Brown, Hendrix and other psychedelic rock/pop, R&B stuff like 60's and early '70's Motown and that sort of thing), and especially jazz and classical). If you're looking for a speaker that makes classic that sort of music sound "right", those are it.
The later W**D and W**E models are a bit of a different animal (The W60D and W60E, sonically-speaking have a lot more in common with the AR3a than the original W60 model, which is closer to a Bozak type of sound). But if you're interested in the W90 models, ALL of them are great (They have a completely-isolated woofer-section... The woofers are isolated from each other as well as the mids and tweeters... Really-nice bass-response).
See the URL in my signature below if you want to get an idea of how the W90's sound...
Pinnacle speakers can be found in that price range. They tend to be fairly efficient and should sing with your Eico. I love the AC650 that can be found for around $100. On the larger end, I have recently rediscovered my JBL L-36's. They also perform well above their going price of around $200. If you can find some late 80's Canton Ergos, that would also be an excellent option in the $500 range. Mission speakers from the late 70's early eighties are wonderful as well. Lots of options in your price range.
I concur with GangTwanger. 1960s Wharfies are the shiznit, I have a pair of early W70Ds driven by a Fisher 500B and they sing! If you prefer acoustic music like jazz or folk, you should look for earlier models though the Ds have no problem with that whatsoever.
