Best cleaners for vintage equipment
Audiodad101
Hello, All,
I was going to begin restoring my Sansui 350A and JVC R-S33. I got my Deoxit, soldering equipment, and multimeter. Is a solder vacuum necessary?
Anyways, I was wondering what is the best cleaner for the wood, aluminum, and acrylic lens?
Also, I'm missing one of the aluminum covers on the front switch. What is a good source for Sansui parts?
Thanks!
For basic cleaning ammoniated window cleaner works fine. EBAY is a good source for Sansui parts. Their prices can be a bit on the high side though. That 350a should be a sweet sounding little receiver. The JVC has twice the power of the Sansui (40 wpc vs 20 wpc)
Thanks for the response. I'll check out Ebay.
I'm really looking forward to getting the 350A working. Hopefully nothing too technical. Main problem is dial doesn't line up with station and I have to turn the volume all the way up to hear anything, even then, it's quiet.
You might be able to slide the dial pointer along the dial string CAREFULLY to get the pointer aligned with the station.
Does it have muting or monitor switches? You might want to check those...with the volume turned DOWN.
Oh, and be careful cleaning the face plate, sometimes the printing will come off. Use a soft damp cloth and maybe some Dawn or similar dish soap for starters.
No mute or monitor switch. I have carefully flipped all the switches and slowly tuned the volume up each time. I only have it hooked up to my Minimus 7's, but I should be getting a lot more out of the receiver.
I'll do my best tnot to use anything harsh on the face plate!
There's a great sticky on one of these forums on how to deep clean a receiver.
While elbow grease is the number one product :), a lot is dependent on what you're trying to clean off (stain/corrosion/nicotine/etc) and what material it is (plastic/metal/bakelite/etc) as well as age/condition/exposure to sunlight, etc.
Sometimes a damp towel takes care of everything, particularly if it's just a layer of hardened dust.
One thing I learned the hard way is be selective and do your research on each model, particularly with lettering on metal faceplates, glass/plastic dials, tubes, etc. Soap and water are usually harmless, but I've read of folks losing lettering on dial glass due to too warm water, windex, etc. I've found tube lettering is particularly delicate so needs a light touch.
For metal with no risk of losing a coating, lettering or it being too shiny (because of matte finish on design) metal polishes like MAGs and Brasso work well. (Brasso has ammonia, so check that's not a problem) If brushed finish, you might want to go with something non-abrasive to maintain the brush patterns. For plastic, I find the novus 3 step cleaner, polish works great.
For detail work, I find q-tips and soft toothbrushes invaluable. Good, unwashed microfiber cloth is also fantastic where you don't want to leave behind little bits of cotton. (microfiber cloths that have been washed with the rest of your laundry are usually loaded (no pun intended) with lint from the rest of the clothes. Magic erasers are also helpful in some cases.
Acetone is great for a lot of stuff but you have to be careful and same with isopropyl alcohol some items will begin to melt if the wrong solvent is used. In some cases this can be an advantage.
A lot of folks like howard's for a quick job on wood finishes, but it does fade as opposed to proper wood prep and stain. I like to do a light sand and restain for wood veneer, but you have to be careful as this can be very thin. Dilute wood bleach can sometimes help with dark stains in wood, but needs to be used sparingly or with multiple light applications.
I knew you'd all be very helpful, thanks! I'll sit back and see what else is recommended. Hopefully I'll at least get it apart this weekend.
