sarpilot
Member
If you are connecting an Onkyo DX C390 CD changer to an Onkyo A9050 Integrated Amp what is the best connection method. The CD changer doesn’t list the type DAC that is installed. It only defines it as a multi bit DAC. The A9050 contains a Wolfson WM 8718 ( 192 kHz 24 bit ) DAC. Should you use the CD changer DAC and use analog connections or use a coax connection to the Wolfson DAC?
