Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Hello,
What would you recommend as cd player (current) w/tube/tubes?...to get a whim of the 'tube sound'. I have an excellent amp+preamp combo, so not interested going tube and replacing those.....
Thanks
I have a Yaqin SD-32A (old model) now it's SD-35A , and it sounds good, it sounded good from the start but I slightly upgraded it, replacing capacitors.
Glad it use 6SN7 tubes, good preamp tubes.
But I use my Grant Fidelity TubeDAC-11 much, (out of production but modified too) since all my music have been ripped on my computer, uses one 6DJ8.
I've had my Jolida Fusion DAC Transport for close to a year.
After a Jolida level 1 cap upgrade and changing the 6 tubes to Genalex Gold Lions, it comes very close if not equals the sound of my vinyl setup.
2 - 12AX7, 2 - 12AT7 & 2 - 12AU7 No opamps in the codec.
I originated a mod, adding an X-10D tube buffer clone inside Onkyo C-7030 CDP's. I built a few, maybe six or seven. Sound great. Vintage Amperex 6DJ8's are my favorite tubes.
You might also consider either a Dac or buffer that uses a tube or two. I use a MHDT dac that has a tube buffer. Very happy with the result. The dac uses a TDA1541 chip set while my cdp uses a PCM1704 chip set. I can experiment with different (but somewhat minor) sound signatures.
If you are trying to get a more “analog” sound I would at least evaluate non-oversampling, R2R DACs.
Uh wow! That's an impressive feat! I saw links on adding a tube buffer stage to a CD player but for most of us a tube buffer, is a lot simpler. But yeah ... impressive feat, for those that can!
impressive...
anyway, going back to the topic...any other CURRENT units that might be recommended...what about Unison Research...anyone familiar with these?
Are they used as the first stage with the OP amps doing the final amplification? I would think they would be used at the end as a buffer, but I've never looked into decks using tubes.
