I finished my antenna project and this is what I learned:
10/3 Just finished a long info exchange with a former broadcast antenna installer or engineer, not sure which one but good info.
1. Use the cable, connectors and tools all from the same vendor, Belden solid copper conductor is where I ended up.
2. Like in the Diagram supplied with all equipment, everything has to be tied to ground and the grounds must all be connected together, the closer to the dirt the better. I ended up with 2 x 8 foot grounding rods on each side of the house tied to both masts, then connected the rods to the power line in box on the outside of the house forming a ring. A strike should divide with half going to each rod.
* Just learned that each coax will need an dedicated rod, so I have to add 4 more rods, then tie the 6 rods together.
3. A whole house surge protectors only costs $50 plus switches and should have been the first step in the project. A strike can travel though the ground and come back into the house via the electrical systems frying everything. This happened to a friend who is an EE, when his neighbor's house was hit. Un-grounded antenna arced through the house to the breaker box and fried fridges, tvs and lots of other appliances all over the development. My friend lost 5 appliances from 3 houses away.
4. I hired a roofer who just finished installing a roof on a new build next to my house to install the tripods, 2x6 cross braces were installed by them in the attic and attached to the trusses. Paid $200, worth every penny. They also installed the ground wires on the tripods and eye rings to the roof. I handed them a bag full of 24 rings, unfortunately they installed every one of them during the 5 minutes I was away, then told me they thought it was too many? My ground wires on the roof aren't moving anywhere, hopefully the tar job they did won't leak all over the place either.
5. We installed 3 FM omni directional antennas, and one UHF aka HD tv antenna. The signal on all 3 is outstanding and IMHO the grounding actually improved the TV picture more than any of the over hyped power conditioners ever did. I am pulling in any decent FM signal within 35 miles of the house. Antennas are mounted approx 35 feet above ground, I am on high ground if there is such a thing in the Chicago area, there are river bottoms which would be insurmountable.
6. Total cost est $1000, $500 parts and $500 labor. $200 for the roofers, and $300 for a friend who installed roof antennas a long time ago. The entire job was probably close to 40 man hours. In addition to the joy of good FM, I cut the cable to Direct TV which will save me $1000 a year. The over the air picture and sound quality are superior to Direct TV to my eyes and ears.
7. If I did it again
A. Day one, Install a whole house surge protector first and have the systems grounding examined and brought up to code.
B. Install 2 grounding rods (one per mast away from electrical service) on each side of the house or at least a few feet apart and tie them to the electrical ground outdoors.
* Install 1 rod per coax.
C. Hire a roofer to install the tripod and cross brace with 2x6 inside the attic. Worth every penny.
D. Plan the house coax wiring like a commercial or military installation in 3 segments. Roof to ground block-rods (4 70 foot runs), from ground lugs to patch panel in basement (4 12 foot runs). On the patch panel install mil spec gas fuses on each line $20 ea. Patch panel to each room that you want antenna in (5 runs longest to attic then back down into a bedroom via the inside wall approx 60 feet). To get to the attic we used a return duct on the HVAC system.
E. Install the inside runs to the patch panel first. Install from the roof to the ground lugs (s) second, then from the lugs to the patch panel. Test the roof runs before attaching them to the grounding lugs, we pulled the wires into the LR via the sliding door and attached them to an FM receiver with signal strength meter and charted every station's reception side by side.
F. Mount the grounding lug in an outdoor attachable plastic enclosure, I used one intended for a pool timer. $20 on Amazon.
* I was told to attach to the lug where the coax is vertical since lightning likes to run strait line to the ground. So the lugs may be out in the weather and coated with pure silicone instead of in a box. Need to think this one through as I don't want water aka ice in the connectors.
G. Leave at least 6 feet of cable gently coiled at each attach point, base of antenna, a loop tied to the gutter downspout we attached to, a loop at the bottom next to the block and loops at the patch panel and plenty of slack in the rooms so you can move the wire around. Don't pull the cable tight anywhere, firmly attach to the mast with lots of high quality electrical tape. If you have to move something, replace an antenna or cable end or make a repair the loops will save you loads of heartburn.
* I may have been wrong on this one from a lightning strike point of view, as I now understand it, run the coax direct to dirt, insert grounding lug where coax is running vertical down the house and direct to a rod. Coax and ground wire running parallel or almost parallel and not exiting coax at 90 degrees as lightning may bypass lug and stay on coax.
* Where the coax enters the house add a drip loop at least one turn around your hand, and add a small piece of close fitting gas pipe into the loop to create more resistance, making it more attractive for the lightning to follow the ground wire and not the coax to your nice stereo.
H Use the best materials:
Channel Master tripods with tar patches for feet included, amazon $35 delivered. Very study.
Belden solid copper core 3x shielded coax and connectors and tools. 100 foot run has zero loss. 500ft $75, tool $90, 25 F conns $18. From
http://www.tselectronic.com/
1 1/4 sae electrical conduit for your mast $9 for 10 feet and superior to any $30 antenna company mast. Buy at any home store.
Mil spec gas fuses can buy from HAM radio companies, I purchase some from L-com but should have gone for the MIL spec ones instead. I am sure both work fine. $20 ea. These are as good or better than any surge protector's coax fuses and you can replace the fuse yourself for $10.
Avoid splitters or amps for the FM signal, use multiple antennas and or a coax switch from a HAM store.
