…I have decided to buy a New integrated for my son. I want something New…
He loves all music…
You don’t write whether a built-in vinyl RIAA preamp-corrector is necessary, and this is characteristic.
For under $500, are there, nowadays, such new integrateds?
No built-in vinyl RIAA preamp-corrector.
A very moderate price, but very complete integrated: “Yamaha AX-397”:
1. Very low THD at nominal powers:
“Minimum RMS Output Power
(8 Ω , 20 Hz to 20 kHz, 0.019% THD)
[AX-397] .............................................................. 60 W + 60 W
(6 Ω , 20 Hz to 20 kHz, 0.038% THD)
[AX-397] .............................................................. 70 W + 70 W
Total Harmonic Distortion
CD, etc. to SP OUT
(20 Hz to 20 kHz, 42.5 W, 8 Ω) ............................. 0.009% or less”.
2. Six inputs, including a built-in vinyl RIAA preamp-corrector for “MM” cartridges.
3. The “monitoring” function, the possibility to duly connect an “outboard” sound processor (equalizers, a 3-head tape deck with the possibility to monitor the sound being recorded, a compressor, a reverberator etc.): “TAPE MONITOR” button.
4. The real “Continuously variable loudness control”, with compensation curves independent of the volume control position. Pay attention to the correct use of this function, described in the “OWNER’S MANUAL”!
