Generally the recommendation for these four transistors is the KSA1220 and KSC2690, or if you really want overkill you could go with the MJE15032 and MJE15033 pair.
With the KSA1220 being killed off I am wanting to save the rest I have for “best used here” purposes. After looking at the specs I’m wondering if the Toshiba TTA004b and TTC004b might be better candidates with their higher Ic, higher Veb and an Ft closer to the originals, maybe less chance of oscillation in certain spots.
Here are the PNP specs for example:
Original
The two options
What do you think, Toshiba a better fit?
Dan
Original
The two options
Dan
