What would be the best stereo test record for someone who is only going to use their ears and not oscilloscopes or other test equipment to evaluate their turntable? Opinions?
The Shure Era IV LP has tests aimed at the ordinary (no test gear) user.
There are any number of sellers' on Discogs that will gladly sell you a copy.
This is more along the lines I was thinking. I don't know how you would compare using a record you were familiar with, since you are playing something on the same turntable you have always used to listen to that record, as some suggested I do.Omnidisc, Hifinews, CBS Labs, Analogue Productions
I am looking to evaluate the turntable I own and have used for the last 40 years. I would like to know how well it tracks, channel balance and a few other parameters. It's more a matter of have I done everything possible to get the best sound out of what I have.You need to be more specific.
Are you asking about a regular music album or a record specically designed to test your system?
Many "test records" don't require special equipment.
Do you want to check alignment, tracking ability, etc. or just overall sound quality?
I do this when evaluating other turntables, but it doesn't work to evaluate my own, since I am only familiar with it and how it currently sounds. I want to know if there is anything I need to do to it to achieve better sound.A record you know well enough to know if it sound different to what you are used from it .
Don't compare it to cd even if it is the same music it will have been mastered differently , so you would be comparing apples to oranges .
Regards F.
I don't know why it was so hard to understand the OP's thread title. He clearly stated, "...Stereo Test Record...", not, "...Record you know very well...". Doug
Hi, neighbor.
