I like this neat old Arvin. It's the only table top I've ever had that pulls in AM stations down here in the basement. Has a woofer and a tweeter powered by push pull 6AQ5s.![]()
The thing about an SX-62 is you can use a modern speaker w/o modification, as its output is 8 ohms...MINE is, anyway. A lot of yr older Boatanchors have 600 ohm outputs, & you have to put in a matching transformer...The SX-62's cabinet was also designed, IIRC, by famed industrial designer Raymond Loewy, the same guy who designed, among other things, the 1953 Studebaker, the Avanti, & the very-classy looking paint scheme on the Kennedy-era Air Force One.
The thing is, you GOTTA get SEVERAL of 'em to decide which one's Da Best...Takin' into account reception, Styling, Sound qualities, Ease of Maintenance, etc...(grin)
Have a Grundig 2120 that's been restored (before I purchased it) and it's a fabulously sounding tube radio from the 50s. As far as getting more than one tube radio, don't stop with just one.
Also have Hallicrafters SX-71, Stewart Warner 9000B from 1947, an old Silvertone battery operated set from the 30s, an Atwater Kent that needs restoration, Heathkit HW-16 ham transceiver, and another tube amp or two around here somewhere....
Ray
The Telefunken Opus 6 and 7 are arguably the finest tube table radios ever made. I have the Opus 7 and I'm absolutely thrilled with it. Best set I've ever owned. And I've been collecting this stuff for 25 years!
You did not mentioned Opus 8 - I wonder why ?
Regards /Ofer
How is the sound quality between Opus 6,7 & 8 ?
Regards /Ofer
