rkay5
1. For LP recording I use a Dell XPS M170 laptop with a E-MU Tracker/Pre(USB) Audio Interface 24bit 192KHz A/D and D/A converters, 32-bit processing USB 2.0 Hi-Speed Full 24-bit resolution at all sample rates
2. The software I use is Audacity. I record at 32 bit, 88.2KHz.
3. I save files at 24 bit, 88.2KHz aiff in iTunes.
4. To burn CD's, iTunes down samples to 16 bit, 44.1KHz on it's own.
5. For cable, I use some 3 meter 3 meter the E-MU Tracker sits with my audio rack
6. First my Thorens TD150 turntable (very modified) outputs to a Creek 4330R phono preamp board. From there, the tape out goes to my the E-MU Tracker. The headphone part has/ analog input and output with volume output control so I have a preamp for the Echo Indigo Io (which doesn't input level control).
7. The Creek 4330R (integrated amp) transfers the audio signal to the E-MU Tracker(USB) audio interface to Audacity (the computer recording software).
8. So why do I recorded at 32bit 88.2KHz and save 24bit 88.2KHz? Just do the math, 88.2 KHz/2 = 44.1 KHz. I have found that I get a better CD this way, than say 96 KHz/2.176870748 = 44100.00001KHz or recording at 16 bit, 44.1KHz. A lot my friend say my CD's made this way sound a lot better than what you get at the store. Oh, the 24 bit, 88.2KHz files sound really damn good. After burning a CD I change the files to Apple lossless in save in iTunes. I'm very happy with this set-up.
The E-MU is much better at what does and sound is better to, than the Echo Indigo. And I payed $130 for a new over at Ebay.
If want to some Hi end vinyl recording look it to the E-MU Tracker/Pre(USB) 24Bit 192KHz it does a great job.
