The pre-amp has two outputs but the parametric EQ only has one so in-order to use the EQ I have to use two splitters to provide input for two amps, and I don't have any good splitters, just junk from Radio Shack, all my interconnects are pretty good pure silver with really good connectors, don't know how much that matters but seems silly to have good expensive interconnects only to have them running thru a pair of cheap splitters.
This may have been covered as I'm not finished reading all the posts. Regarding your EQ - hook it up the the tape 1 loop and
not from the pre -> eq ->amp. This is the way it's "supposed" to be done. Your setup works until you need a second amp. I've did the same as you until I hooked up my QLS-IIIs with 2 bridged mono amps Vertical bi-amp). I switched my EQ to tape 1 loop. You can then take the EQ out of the signal path with a flip of a switch. With the other setup you still have the EQ in the listening chain regardless if its on or not. With a new setup I'm messing with I usually do not listen with an EQ until I've got my system sounding the way I like it then I fine tune (if need be) with the EQ.
Regarding the active crossover used in combination with passive crossover. You're not going to get any if at all sonic improvement without changing
the passive crossover. I'm not familiar with the passive one on your speakers but some speakers I have have a passive crossover with different wire hookups (adjustable on the crossover) for bi-amp, tri-amp etc. Change a few wires (jumpers) and you can add amps. Still passive crossover in the chain so I would not expect too much improvement sonically with an active crossover without changing the passive crossover.
You can however increase your amps efficiency with an active crossover splitting the signal from the pre to the amp with the active crossover. pre -> active X-ver - Amp1 & Amp2 (and changing your passive crossover). Be sure to get some overlap and let the passive crossover in the speaker do it's thing. (horizontal Bi-amp).
Amp1 -> mids/highs, Amp2 -> Watkins. I'm suspecting this was your goal - give the Watkins just the low signal they need to make your amp more efficient. It will work but as mentioned the crossover point needs to be addressed for best sound. I've found the vertical bi-amp to work for me, full range to each speaker but wattage x2 the stereo output (in my case) in mono, since the amps are bridged. Somewhat better more clear sound and punch as I've got more horsepower to each speaker. Again this is with the QLS-III not your setup. QLS-IIIs don't have any settings for bi-amp, so this works best for me.
I've messed with this with other speakers and decided the extra active crossovers I was using were adding (actually taking away) too much from the sound, with regard to clarity. Could have been the crossovers but they were Rane... Just didn't give me much of anything worthwhile sound wise. Sometimes more = less, in my case I thought so. Please excuse me if some of this was covered. It's my experience with active crossovers.
To sum it up - the speakers I have that have jumpers for bi-amp, they sound better without any active crossover, full range and let the crossover do it's thing. I bet I could get it to work with the active crossover, but I think I need more equipment for testing purposes to be able to match/beat the crossover designers, oh and a lot of free time on my hands.
YMMV of course.
Cheers,
Bob
