Sort of an indirect question. Here is the story. In my attic, I have a rabbit ears antenna connected with 300 ohm flat cable to my tuners’ (one at a time of course) 300 ohm antenna connections. I am very satisfied with its performance.
I also have one of those Amazon uni directional 75 ohm coax antennas in the attic connected through a coax cable. When used with a tuner that has a 75 ohm input, this antenna does not perform as well as the rabbit ears setup I have, when run into the same tuner’s 300 ohm input.
I would like to use this coax cable run, but replace the Amazon uni antenna with rabbit ears. I hear matching transformers are lossy, so the question is, can I simply have one rabbit ear to the shield and the other to the center conductor? Or would I be better off with a matching transformer? Also, what impedance would any of these configurations be?
