cougit25
Hi Guys. Please help, I am perplexed. :scratch2: I have read a few posts that suggest bi-wiring speakers by using different taps on the amp one for the woofers and another for the mids and tweeters. I am confused because although it is called bi-wiring it would seem to be bi-amping. My logic says that it is only bi-wiring due to the fact that it is still only one amp, but the different taps throw in another variable that I don't completely understand. :headscrat How does the amp see these different loads at it's different taps? If I hooked up one 8 ohm speaker to the 4 ohm tap and another 8 ohm speaker to the 8 ohm tap, what kind of load would the amp see? Two 8 ohms loads in parallel or two 8 ohm loads in series?
It sounded so much better. Well it was biwiring from then on! :yes: Now my system is configured the way it should be with the amp next to the speakers and short speaker wires and interconnects to the other components. The speaker wire I'm using now is a custom biwire set that my McIntosh dealer madeup for me with one set of spades on the amp end and two sets of banana plugs on the speaker end. It's not exotic wire and didn't cost much at all, but it sure sounds good.
