I've been reading a lot about bi-wiring speakers, and have a couple of questions.
First, and most specific, my bi-wire capable speakers are 8 ohm nominal, when single wired with jumpers. My amp has A & B speaker outputs. I run the A out to the woofers, the B out to the MTM. Does my amp react as if it has a 4 ohm load(2 parallel 8 ohm loads)?
The second, more general question, refers to running a single wire out, and splitting to bi-wire configuration at the speaker. While the circuit is electrically the same as running separate wires to hi/lo, some people claim that there is a noticeable difference between the two configurations, and some say it's impossible to hear the difference. I would assume that I gain an electrical advantage at the amp by increasing the the effective wire gauge by running two sets of wires. Could this be enough difference to be audible, in some systems, versus the extremely short(relatively) split in a single/bi-wire set-up?
