Rocco
Member
I have some old Roger Sound Labs G8 Speakers that can be either Bi-Amped and/or Bi-Wired. Many years ago I set them up Bi-Wired to a single amp. I used double set of wires and remember it was pretty tough winding all that wire to fit into a single tap at the back of amp.
I since switched to running them standard (single wire) and used some kind of "shorting" bar across one set of speaker taps, then just wiring into the other set. Well, I lost those shorting bars--
Can I just make each single wire lead wrap around both taps?
I think that's how I did it once before, but it's been several years since I changed things around back there and just wanted to double check with you guys. (Actually, the speakers taps are on the bottom of this big tower speaker, not on the back--so it's also a job to lay them down and get under there!)
