sort of a double post, was just hoping maybe some more eyes would see this.
Crown DC-300A series II amp. Trying to do the bias level adjustment. in the service manual, does not really say where to take the measurements, just mentions the base-emitter.
On the amps up to serial number 81323, there is a resistor you change to set the bias and you measure the current at R132, R139 and R232, R239 - but on amps with serial number 81324 and higher, which I have, there is no R139 or R239 on the output boards, or the main board from what I can see.
The Service manual does not have a schematic for the output boards, just a parts list, and in the parts list for serial numbers 81324 and up, the resistors start at R300 - no R129 or R239 to be found.
So, I ended up taking the reading directly off of the output transistors and adjusted the dc to .31 per the manual. I just could not figure out where to take the reading. Thought it was all figured out, took the readings from the output transistors, dialed right in to .31vdc.
re-checked it after an hour and still maintained the .31vdc.
Hooked it up. Thought all was well. Was playing some kids music(mp3's) for my grand daughter, turned it up a little and one of the speakers made a real loud POP, sounded like a gunshot - was not cranking it at all.
Scared the bejeebers out of grand daughter and one of the dogs.
Tried it again, same result - no meters, but i am guessing the peaks were still under 30 watts.
So, I am guessing I did not adjust the bias correctly ? Or it needs some other work done on it ?
Doubt it is speakers as I have been using them for a while and have had them at least twice as loud as i was playing tonight.
anyway - is taking the readings on the output transistors right ? If not, anyone have any idea where you take the readings as there are no R129 or R239 on this series of amp.
Thanks for any info, sorry for double posting - is just driving me nuts
