EL504
this amp is triode mode, not UL, and probably runs in AB2 mode but for voltage and current purposes at idle its pretty similar. The Ia+g2(0) line is idle current plate + screen with zero signal, 50ma per-tube in the 460 plate volts column.
The schematic of this amp shows tetrode connection, so not triode mode.
These are the frequency response and distortion graphs from the manual of the Luxman MB88 Ultimate. These show 60 to 70 Watt maximum output power.
Based on these graphs, the measured plate and screen voltages, and datasheets for the KT88, I think this amplifier runs in AB1, so without control grid current.
Running this amp at 50 mA per KT88 at idle seems a bit low to me. I would think 60 mA per KT88 at idle (which results in 27.78 Watt plate dissipation) would be more in line with the datasheets for the KT88.
Edit: The manual I found is in Chinese. I couldn't find info on bias in it. But if Luxman is still in business, you could ask them.
