I'm revisiting my HK TA5000x rebuild and since I could never decide what to bias output tubes at, the receiver was on the "to do someday" shelf. The output stage is basically cathode biased but I made it adjustable to be able to use "best matched" pairs of 7355 tubes I have. If I bias treating it as cathode biased stage, at 46mA of cathode current per tube, which is a little cool for P-K=346v, the receiver runs like a stove. I'm looking for suggestions for bias point. If I were to treat it as AB1 and bias at around 35mA of cathode current, what is the best and most accurate way to catch crossover/notch distortions if it ends up too cool? Or, is there a way to determine the optimal bias point judging by the cathode current difference between idle and max power? Here is the original schematic:
Here is one with my modifications, including Zeners across the heater string:
Thanks for the suggestions!
