Hi everyone, recently I acquired a vintage BIC 940 Turntable. I have cleaned everything up and the turntable is now working amazing. The only problem i'm hoping someone could help me out with has to do with the cycling cam. For whatever reason when the turntable auto returns and shuts off, it seems that the cycling cam is going just a few teeth too far because the tonearm will lift up and move inward before the platter stops spinning, leaving the arm suspended in the air. Spinning the platter backwards seems to get it out of cycle, but this is a little bit annoying. Has anyone experienced this problem who has owned a 940, and if so, were you able to fix it?
