OK, the good news first:
* I tore the whole thing apart per the youtube videos, degreased, regressed and reassembled. It was much easier (and more fun!) than I was expecting ... with the exception of the dang platter mat.
* I scored a set of pristine Avid 100s from the original owner off CL today. For the time being, I don't want to tear apart the system that the B&Ws are attached to and I like the idea that these Avids are period correct. They also have a reputation for very clean, uncolored sound and I listen almost exclusively to jazz ... so I'm stoked.
The bad news:
* When I popped off the motor cover to maintenance it, I noticed there is no "magnet assembly" at the top of the shaft as is referenced in the repair videos at 2:50 (
) ... it seems damn near impossible that anyone has ever opened that motor case before ... could this simply be a difference between the 940 that is being worked on in the video vs my 960? It's a little disconcerting.
* With everything back together I reassembled, plugged it in, set a record on the spindle, set the program switch to 1 and hit the cycle button. The platter spins (yeah!) and the record dropped ... but the tone arm doesn't move (yes, its unlocked) and after about 20 seconds or so the program switch automatically drops down to manual. Any ideas What might be wrong?
* Lastly, is there is a trick to getting the @#*&! mat back on? I have literally spent 30 solid minutes trying to get it hooked in properly but the last 2/3 is impossible. At one point I thought I had it but a spin on the turntable made it clear that it was not tight all the way around.
I appreciate any guidance. Thanks much.
ZZ
