Tucker_515
The purpose of this post is to be both informative to readers and helpful to me! A few months ago, I purchased a pair of BIC Venturi Formula 6 speakers and I love them. They are perfect for my music, which is mainly rock '70s to present, but can be anything besides country and new computerized music.
--To clarify, the BICs I talk about in this post are the first generation with 6 drivers: one 12" woofer, one 5" mid, two horn tweeters, and two super tweeters. They measure 15.75" wide X 14.75" deep X 26.25 tall and weigh 62 lbs each. They are rated at 125 watts (RMS or peak I am not sure, this info comes from the original brochure) and have 6 ohm impedance. There advertised frequency response is 20Hz-23KHz, I don't know the +/- 3 db, yet. --
I loved my first pair so much, I found another pair and picked them up. Again, these are both the 6 driver version, but they are different. It is my understanding that there are two versions of the first generation, easily identified because one version has paper super tweeters, and the other has piezo super tweeters. See pictures below, there are also some minor aesthetic differences.
There is not much information about these BICs and even less about the differences between the first versions. I pulled a woofer from each, because I want to rebuild the crossovers, and found some more differences. First off, the crossovers are in different spots, which obviously doesn't do anything, but is still curious. The large difference is that the crossovers are not the same. There are schematics for both crossovers in the speakers themselves, which I thought was cool. Pictures of everything are all attached.
I believe the version with the paper super tweeters came first and the version with the piezo's came second because the woofers from the former are stamped BIC 120 and the crossover sheet says Model Formula 6, while the latter woofers are stamped BIC 120b and the crossover sheet says Model Formula 6-1a.
So my question is, should I rebuild the crossovers as they are, or should I upgrade one to the other? I assume I should leave them as they are, because that's how they are designed, but I am no expert.
Please, if anyone has any questions or more information about these, let me know! I'll do my best to post as many pictures as possible and document what drivers each have. I really love these and they tend to get bad reviews because of the second generation that shares the same name, but are very different. Thanks for reading!
