Zolton
Well-Known Member
I'm messing with a well used Harman Kardon 430 and getting ready to set the bias. The technical manual says to use a 50 watt 8 ohm resistor as a dummy load at the speaker terminals. I came across this large adjustable resistor (rheostat?). It's an Ohmite Model R made in Skokie Ill. We all have this sort of thing just sitting around don't we? :yes:
It's adjustable from zero up to 25 ohms and is rated for 4.47 Amps and 600 volts max.
Can I use this as my dummy load?
